KarimElsayad247
Altostratus
Feb 21, 2023Problem with connecting using f5 vpn on Ubuntu/Linux; stuck on "Connecting..."
This issue happens only on the machine I'm using, I treid the same account on multiple other machines, on the same network and other networks. The gist of it is that f5vpn gets stuck in the connectin...
spallaire
May 26, 2023I have the same problem since upgrading my Ubuntu Distro. And like you, works in containers hosted by the problematic machine.
- KarimElsayad247May 26, 2023
Altostratus
My problem disappeared after I installed Ubuntu 22. I don't know whether it went away because I upgraded our because I wiped my device, giving it a fresh start.
- spallaireMay 26, 2023
Nice to know, I might try a fresh instal then.
- spallaireJun 05, 2023
Tried multiple "solution" found accross the web with no chance.
Made a fresh install of 23.04 and started working as before.
Unfortunately I have no good guess of what it was, better chance to the next one.
