Problem with connecting using f5 vpn on Ubuntu/Linux; stuck on "Connecting..."
Do you see any obvious errors in the log files?
What do you see in svpn.log when you compare a working system to your not working system? Presumably the logs must be different between the two. The difference should help narrow down what the issue might be.
You might also review Ubuntu's AppArmor settings or temporarily disable it, as these might block networking changes that the f5vpn process is trying to perform:
https://help.ubuntu.com/community/AppArmor
Here is a pastbin contaning my previously posted replies, since this forum unfortunately does not support txt files.
