Problem with connecting using f5 vpn on Ubuntu/Linux; stuck on "Connecting..."
Do you see any obvious errors in the log files?
What do you see in svpn.log when you compare a working system to your not working system? Presumably the logs must be different between the two. The difference should help narrow down what the issue might be.
You might also review Ubuntu's AppArmor settings or temporarily disable it, as these might block networking changes that the f5vpn process is trying to perform:
https://help.ubuntu.com/community/AppArmor
- KarimElsayad247Feb 23, 2023
Altostratus
As for /var/log/svpn.log
2023-02-23,13:41:04:158, 160816,160816,svpn, 0,,,, =====================================
2023-02-23,13:41:04:158, 160816,160816,svpn, 0,,,, Location: /opt/f5/vpn/svpn
2023-02-23,13:41:04:158, 160816,160816,svpn, 0,,,, Version: "7220.2022.0308.1"
2023-02-23,13:41:04:158, 160816,160816,svpn, 0,,,, Locale: C
2023-02-23,13:41:04:158, 160816,160816,svpn, 48,,,, current log level = 63
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 132, ------------------,
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 133, [main], getuid, 1000
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 134, [main], getgid, 1000
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 135, [main], geteuid, 0
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 136, [main], getegid, 1000
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 137, [main], HOME, /home/karim
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 139, [main], version, 7220.2022.0308.1
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 141, ------------------,
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 148, [main], Current sigprocmask: 0x14a3dec0
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 46, ReadProperties() Select retruns the pipe data size : , 3915,
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 51, ReadProperties() Pipe Read lopp ,
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 55, ReadProperties() read() , 3915, <VERY LONG LINE>
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 62, ReadProperties() reading pipe : , 3915, <VERY LONG LINE IDENTICAL TO ONE ABOVE>
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 72, ReadProperties() after reading the data from pipe : , 3915, <VERY LONG LINE IDENTICAL TO ONE ABOVE>
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 83, ReadProperties() Data send by Edge Client over pipe : , <VERY LONG LINE IDENTICAL TO ONE ABOVE>
2023-02-23,13:41:04:160, 160816,160816,svpn, 48, , 99, ReadProperties(), ,
2023-02-23,13:41:04:160, 160816,160816,svpn, 48, , 99, ReadProperties(), q0, 3C786D6C617474723E3D
// many lines filled with what seems like randome nubers after like so:
// I removed them from the log to fit them in a single message, the number
// here is an example
2023-02-23,13:41:04:163, 160816,160816,svpn, 48, , 99, ReadProperties(), q34, 697679696EDA67DA9E6D7796F976D97E697A6F97E6697A6D96A0F2023-02-23,13:41:04:163, 160816,160816,svpn, 48, , 99, ReadProperties(), q77, 3D
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), <xmlattr>, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), session_id, 5df83964, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_sidhash, 5df83964, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_z, /Common/<VPN_GROUP>, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_name, /Common/<VPN_GROUP>, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), host0, 127.0.0.1, 127
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), port0, 44444, 44444
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_type, VPN, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_connect, auto, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), tunnel_protocol0, https, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), idle_session_timeout, 5400, 5400
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), firepassserver0, /Common/<VPN_GROUP>, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ipv4_0, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ipv6_0, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), tunnel_dtls, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dns0, 192.168.168.49 1.1.1.1, 192
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dns6_0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), wins0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dnssuffix0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dnsregisterconnection0, 2, 2
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dnsusednssuffixforregistration0, 2, 2
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), splittunneling0, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), lan0, 192.168.2.7/255.255.255.255 192.168.2.12/255.255.255.255 192.168.168.0/255.255.255.0 192.168.80.18/255.255.255.255 192.168.60.31/255.255.255.255 192.168.155.21/255.255.255.255 192.168.2.23/255.255.255.255 192.168.30.20/255.255.255.255 192.168.155.50/255.255.255.255, 192
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), lan6_0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), excludesubnets0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), excludesubnets6_0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dns_split0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), excludedomainnames0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), allowlocalsubnetaccess0, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), allowlocaldnsserversaccess0, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), allowlocaldhcpaccess0, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), add2hosts0, <SUB_DOMAIN>.<COMPANY_NAME>.<TLD>|192.168.2.23|<SUB_DOMAIN>.<COMPANY_NAME>.<TLD>|192.168.2.23|<SUB_DOMAIN>.<COMPANY_NAME>.<TLD>|192.168.30.20|<SUB_DOMAIN>.<COMPANY_NAME>.<TLD>|192.168.80.18, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_donotwarnuser, no, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), clientformicrosoftnetworks0, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), fileandprintersharingformicrosoftnetworks0, 2, 2
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), enforcednsorder0, ON, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_disableclientcerts, no, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dontreportpolicy0, TRUE, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), processtimeout0, -1, -1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), hdlc_framing, no, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), autoreconnectifdropped0, yes, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), tcp_reconnect_timeout0, 900000, 900000
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), tcp_reconnect_delay0, 200, 200
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), trafficcontrol0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_powermanagement, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), displayedbandwidth0, 100000000, 100000000
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_connect_msg0, NO, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_networktunnelenabled, yes, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_optimizedappsenabled, no, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), minimize_after_connect0, YES, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_ctrlchannelenabled, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_isessionenabled, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_connect_msg_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_connect_fallback_msg_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_routing_changes_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_process_check_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_registry_check_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_config_error_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_os_patch_check_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_ie_patch_check_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_pf_check_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), tunnel_host0, <COMPANY_DOMAIN>, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), tunnel_port0, 443, 443
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), browser_pid, 160796, 160796
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), version, 2.9, 2
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), , , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), client_pid, 160796, 160796
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), HOST, <COMPANY_DOMAIN>, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), PORT, 443, 443
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), UseDefaultGateway, OFF, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), AllowLocalSubnetAccess, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), AllowLocalDHCPAccess, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), AllowLocalDNSServersAccess, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), LAN, 192.168.2.7/255.255.255.255 192.168.2.12/255.255.255.255 192.168.168.0/255.255.255.0 192.168.80.18/255.255.255.255 192.168.60.31/255.255.255.255 192.168.155.21/255.255.255.255 192.168.2.23/255.255.255.255 192.168.30.20/255.255.255.255 192.168.155.50/255.255.255.255, 192
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ExcludeSubnets, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), EnforceRouteTable, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), txqueuelength, 100, 100
2023-02-23,13:41:04:166, 160816,160817,svpn, 48, , 1369, SSLVpn::svpn(), Open(), setuid, 1000, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 48, , 662, CString ResolveHostNameGetFirstIp(const CString&), Resolved '<COMPANY_DOMAIN>' to <COMPANY_IP>
2023-02-23,13:41:04:166, 160816,160817,svpn, 48, , 716, void SSLVpn::ConfigureTunnelChannel(), U_TUNNEL_HOST=<COMPANY_DOMAIN>
2023-02-23,13:41:04:166, 160816,160817,svpn, 48, , 11, UTunChannel::UTunChannel(), Initializing...
2023-02-23,13:41:04:166, 160816,160817,svpn, 48, , 42, UTunChannel::CloneDevice(), Opening utun device
2023-02-23,13:41:04:167, 160816,160817,svpn, 48, , 296, UTunChannel::IsDeviceAvailable(), Device is available
2023-02-23,13:41:04:167, 160816,160817,svpn, 48, , 751, SSLVpn::ConfigureTunnelChannel(), Tun device will be used
2023-02-23,13:41:04:167, 160816,160817,svpn, 48, /UChannelChain.cpp, 55, , enter, 0x80f: U_ENABLE_SOCKET_CHANNEL U_ENABLE_SSL_CHANNEL U_ENABLE_PROXY_CHANNEL U_ENABLE_HTTP_CHANNEL U_ENABLE_PPP_EMULATION_CHANNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 48,,,, USSLChannel::USSLChannel:RAND_status(1)
2023-02-23,13:41:04:167, 160816,160817,svpn, 48, /UF5FramePacketizerChannel.cpp, 293, UF5FramePacketizerChannel::setProperties(), fast framing will be used
2023-02-23,13:41:04:167, 160816,160817,svpn, 48, /UHTTPChannel.cpp, 593, UHTTPChannel::setProperties(), m_bFastPPPMode, true
2023-02-23,13:41:04:167, 160816,160817,svpn, 48, /UHTTPChannel.cpp, 597, UHTTPChannel::setProperties(), m_bUseISession, false
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, --------- Initial State --------
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, Address Netif
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 127.0.0.1/8 lo( 1)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 192.168.1.10/24 wlp5s0( 3)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 192.168.122.1/24 virbr0( 4)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.19.0.1/16 br-63dcbff36084( 6)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.20.0.1/16 br-74660eaa12c1( 7)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.18.0.1/16 br-9ebcc5f112e6( 😎
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.22.0.1/16 br-9fdcc1944e6d( 9)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.23.0.1/16 br-3e8ed22008b1(10)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.21.0.1/16 br-4c314f5c6ea9(11)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.25.0.1/16 br-5202490322d8(12)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.17.0.1/16 docker0(13)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, ::1/128 lo( 1)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::ed58:cb1a:4464:9231/64 wlp5s0( 3)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::42:e7ff:fe94:e6/64 br-63dcbff36084( 6)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::42:e2ff:fed4:1fd9/64 br-74660eaa12c1( 7)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::42:95ff:fe06:54cd/64 br-9ebcc5f112e6( 😎
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::5c94:c1ff:feec:be64/64 veth5ae8a4c(15)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::a44a:ffff:fe33:1781/64 veth0d86702(17)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::38c1:2dff:fef1:f19c/64 veth30a69c9(19)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::2c13:38ff:fe1d:1e67/64 vethe81d240(21)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, Destination Gateway Flags Netif Expire Proto Preferred Source Address
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 0.0.0.0/0 192.168.1.1 UG wlp5s0(3) 0 RTPROT_DHCP
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 169.254.0.0/16 link#4 U virbr0(4) 0 RTPROT_BOOT
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.17.0.0/16 link#13 U docker0(13) 0 RTPROT_KERNEL 172.17.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.18.0.0/16 link#8 U br-9ebcc5f112e6(8) 0 RTPROT_KERNEL 172.18.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.19.0.0/16 link#6 U br-63dcbff36084(6) 0 RTPROT_KERNEL 172.19.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.20.0.0/16 link#7 U br-74660eaa12c1(7) 0 RTPROT_KERNEL 172.20.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.21.0.0/16 link#11 U br-4c314f5c6ea9(11) 0 RTPROT_KERNEL 172.21.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.22.0.0/16 link#9 U br-9fdcc1944e6d(9) 0 RTPROT_KERNEL 172.22.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.23.0.0/16 link#10 U br-3e8ed22008b1(10) 0 RTPROT_KERNEL 172.23.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.25.0.0/16 link#12 U br-5202490322d8(12) 0 RTPROT_KERNEL 172.25.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 192.168.1.0/24 link#3 U wlp5s0(3) 0 RTPROT_KERNEL 192.168.1.10
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 192.168.122.0/24 link#4 U virbr0(4) 0 RTPROT_KERNEL 192.168.122.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, ::1/128 link#1 U lo(1) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#8 U br-9ebcc5f112e6(8) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#15 U veth5ae8a4c(15) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#17 U veth0d86702(17) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#6 U br-63dcbff36084(6) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#19 U veth30a69c9(19) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#21 U vethe81d240(21) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#7 U br-74660eaa12c1(7) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#3 U wlp5s0(3) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, ::/0 fe80::a5a:11ff:fe42:d3b0 UG wlp5s0(3) 0 RTPROT_RA
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, --------- End --------- KarimElsayad247Feb 23, 2023
Altostratus
2023-02-23,13:41:06:167, 160816,160817,svpn, 48, , 1505, SSLVpn::svpn(), We're connecting...2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 1508, SSLVpn::svpn(), ServerReachable! Let's connect!2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 1171, SSLVpn::ConnectChannels(), -------------------------------------2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 1186, SSLVpn::ConnectChannels(), -------------------------------------2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 1187, SSLVpn::ConnectChannels(), Let's try to connect Tunnel Channel2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 662, CString ResolveHostNameGetFirstIp(const CString&), Resolved '<COMPANY_DOMAIN>' to '<COPMANY_IP>'2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 803, CLinuxRouteTable::GetBestRoute2, <COMPANY_IP>2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 642, SHORT GetMTUForPPP(CLinuxRouteTable&, const CString&, bool), Best route to APM (<COMPANY_IP>): <COMPANY_IP>/32 192.168.1.1 U wlp5s0(3) 0 RTPROT_UNSPEC 192.168.1.102023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 647, SHORT GetMTUForPPP(CLinuxRouteTable&, const CString&, bool), Physical interface MTU=1500, desired tunnelMRU=13842023-02-23,13:41:06:168, 160816,160817,svpn, 48, /UHTTPChannel.cpp, 703, UHTTPChannel::setProperties(), m_bFastPPPMode, true2023-02-23,13:41:06:168, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 118, UF5PPPEmulationChannel::Open(), enter2023-02-23,13:41:06:168, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 35, CLinuxEventHandler::HandleEvent(), enter, 152023-02-23,13:41:06:168, 160816,160817,svpn, 48, /EventHandlerImplBase.h, 239, , Unknown event, EVENT_TYPE_FP_SESSION_GET_CURRENT, 02023-02-23,13:41:06:168, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 68, CLinuxEventHandler::HandleEvent(), exit with, 32023-02-23,13:41:06:168, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 35, CLinuxEventHandler::HandleEvent(), enter, 222023-02-23,13:41:06:168, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 68, CLinuxEventHandler::HandleEvent(), exit with, 02023-02-23,13:41:06:319, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 35, CLinuxEventHandler::HandleEvent(), enter, 232023-02-23,13:41:06:320, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 68, CLinuxEventHandler::HandleEvent(), exit with, 02023-02-23,13:41:06:320, 160816,160817,svpn, 48, /USSLChannel.cpp, 342, , socket receive timeout set (seconds), 302023-02-23,13:41:06:320, 160816,160817,svpn, 48,,,, USSLChannel::Open() - select return 12023-02-23,13:41:06:320, 160816,160817,svpn, 48, /UHTTPChannel.cpp, 305, UHTTPChannel::beginConnection(), hdlc_framing=no2023-02-23,13:41:06:575, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 35, CLinuxEventHandler::HandleEvent(), enter, 12023-02-23,13:41:06:575, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 43, CLinuxEventHandler::HandleEvent(), EVENT_TYPE_SELECT_CLIENT_CERT2023-02-23,13:41:06:575, 160816,160817,svpn, 1, /LinuxEventHandler.cpp, 1009, LinuxEventHandler::verifyServerCert(), Not launched from CLI ignoring cert check2023-02-23,13:41:06:575, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 68, CLinuxEventHandler::HandleEvent(), exit with, 32023-02-23,13:41:06:981, 160816,160817,svpn, 48, /UHTTPChannel.cpp, 423, UHTTPChannel::beginConnection(), find header pos, 952023-02-23,13:41:06:982, 160816,160817,svpn, 48, /UHTTPChannel.cpp, 467, UHTTPChannel::beginConnection(), server returned HTTP code, 2002023-02-23,13:41:06:982, 160816,160817,svpn, 1, /USSLChannel.cpp, 484, USSLChannel::Open(), U_TUNNEL_TRANSPORT_SECURITY_EXCH_ALGO, ECDH2023-02-23,13:41:06:982, 160816,160817,svpn, 1, /USSLChannel.cpp, 489, USSLChannel::Open(), U_TUNNEL_TRANSPORT_SECURITY_CIPHER_ALGO, AESGCM(128)2023-02-23,13:41:06:982, 160816,160817,svpn, 1, /USSLChannel.cpp, 494, USSLChannel::Open(), U_TUNNEL_TRANSPORT_SECURITY_HASH_ALGO, AEAD2023-02-23,13:41:06:982, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 857, UF5PPPEmulationChannel::ChangePhase, Current link phase is Dead, switching to Establish2023-02-23,13:41:07:186, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1077, UF5PPPEmulationChannel::DispatchAction(), LCP up2023-02-23,13:41:07:186, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1086, UF5PPPEmulationChannel::DispatchAction(), Negotiated remote MRU: 12512023-02-23,13:41:07:187, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1104, UF5PPPEmulationChannel::DispatchAction(), Negotiated local MRU: 12512023-02-23,13:41:07:187, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 857, UF5PPPEmulationChannel::ChangePhase, Current link phase is Establish, switching to Authenticate2023-02-23,13:41:07:187, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 857, UF5PPPEmulationChannel::ChangePhase, Current link phase is Authenticate, switching to Network2023-02-23,13:41:07:394, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1726, UF5PPPEmulationChannel::ProcessControlMessage(), Unknown protocol, 328552023-02-23,13:41:07:394, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1734, UF5PPPEmulationChannel::ProcessControlMessage(), Sending Protocol-Reject2023-02-23,13:41:07:596, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1113, UF5PPPEmulationChannel::DispatchAction(), IPCP up2023-02-23,13:41:07:596, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1125, DispatchAction, Local address: 192.168.3.1272023-02-23,13:41:07:596, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1126, DispatchAction, Remote address: 1.1.1.12023-02-23,13:41:07:596, 160816,160817,svpn, 1, /USSLChannel.cpp, 484, USSLChannel::Open(), U_TUNNEL_TRANSPORT_SECURITY_EXCH_ALGO, ECDH2023-02-23,13:41:07:596, 160816,160817,svpn, 1, /USSLChannel.cpp, 489, USSLChannel::Open(), U_TUNNEL_TRANSPORT_SECURITY_CIPHER_ALGO, AESGCM(128)2023-02-23,13:41:07:596, 160816,160817,svpn, 1, /USSLChannel.cpp, 494, USSLChannel::Open(), U_TUNNEL_TRANSPORT_SECURITY_HASH_ALGO, AEAD2023-02-23,13:41:07:596, 160816,160817,svpn, 48, , 841, SSLVpn::OpenTunnelChannel(), Proxy,2023-02-23,13:41:07:596, 160816,160817,svpn, 48, , 857, SSLVpn::OpenTunnelChannel(), IP addresses: , 192.168.3.127, 1.1.1.12023-02-23,13:41:07:596, 160816,160817,svpn, 48, , 868, SSLVpn::OpenTunnelChannel(), IPv6 addresses: , ,2023-02-23,13:41:07:596, 160816,160817,svpn, 48, , 1193, SSLVpn::ConnectChannels(), -------------------------------------2023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 1194, SSLVpn::ConnectChannels(), Let's try to connect PPPD Channel2023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 803, CLinuxRouteTable::GetBestRoute2, 255.255.255.2552023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 268, CLinuxRouteTable::GetIfaceAddr2, IFace, 32023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 268, CLinuxRouteTable::GetIfaceAddr2, IFace, 32023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 288, UTunChannel::setProperties(), IP, mtu, 192.168.3.127, 1.1.1.1, 12512023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 109, UTunChannel::Open(), Opening utun interface2023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 42, UTunChannel::CloneDevice(), Opening utun device2023-02-23,13:41:07:598, 160816,160817,svpn, 48, , 178, UTunChannel::Open(), Device opened, tun0, 412023-02-23,13:41:07:602, 160816,160817,svpn, 48, , 1228, SSLVpn::ConnectChannels(), communication channels opened2023-02-23,13:41:09:170, 160816,160817,svpn, 48, , 268, CLinuxRouteTable::GetIfaceAddr2, IFace, 412023-02-23,13:41:09:618, 160816,160817,svpn, 48, , 803, CLinuxRouteTable::GetBestRoute2, 1.1.1.12023-02-23,13:41:09:618, 160816,160817,svpn, 48, , 268, CLinuxRouteTable::GetIfaceAddr2, IFace, 412023-02-23,13:41:10:170, 160816,160817,svpn, 48, , 803, CLinuxRouteTable::GetBestRoute2, 1.1.1.1...more than 3700 lines of same thing...2023-02-23,14:08:54:351, 160816,160817,svpn, 48, , 268, CLinuxRouteTable::GetIfaceAddr2, IFace, 412023-02-23,14:08:55:351, 160816,160817,svpn, 48, , 803, CLinuxRouteTable::GetBestRoute2, 1.1.1.12023-02-23,14:08:55:351, 160816,160817,svpn, 48, , 268, CLinuxRouteTable::GetIfaceAddr2, IFace, 41```For all these logs, I've replaced sensitive info such as specific ips, company domains and subdomains, and vpn group with generic tokens.Something worth noting is that I could patch the hosts file manually, add manually add some routes to my ip table pointing at vpn (at tun0 address) and I would connect to those specific domain names, however I wouldn't be able to receive callbacks from them, and f5vpn would still display connecting state.
