KarimElsayad247
Altostratus
Feb 21, 2023Problem with connecting using f5 vpn on Ubuntu/Linux; stuck on "Connecting..."
This issue happens only on the machine I'm using, I treid the same account on multiple other machines, on the same network and other networks. The gist of it is that f5vpn gets stuck in the connectin...
Lucas_Thompson
Employee
Feb 22, 2023Do you see any obvious errors in the log files?
What do you see in svpn.log when you compare a working system to your not working system? Presumably the logs must be different between the two. The difference should help narrow down what the issue might be.
You might also review Ubuntu's AppArmor settings or temporarily disable it, as these might block networking changes that the f5vpn process is trying to perform:
https://help.ubuntu.com/community/AppArmor
