davmec_127271's avatar
davmec_127271
Nov 12, 2004
problem using LocalLB.Pool.add_member
Hi!
I have been trying this code without success (no node added to the pool)
   use SOAP::Lite + trace => qw(method debug);
   use iControlTypeCast;
   $Pool = SOAP::Lite
     -> uri('urn:iControl:LocalLB/Pool')
     -> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
   $thepool = "NWG_WAP2";
   $node = {address => "10.200.16.51", port => 8080};
   $soapResponse = $Pool->add_member
     SOAP::Data->name(pool_names => [$thepool]),
     SOAP::Data->name(members => [$node])->type("IPPortDefinition"')
   &checkResponse($soapResponse);
Then the command line output looked like this (sorry for the length):
   SOAP::Transport::new: ()
   SOAP::Serializer::new: ()
   SOAP::Deserializer::new: ()
   SOAP::Parser::new: ()
   SOAP::Lite::new: ()
   SOAP::Transport::HTTP::Client::new: ()
   SOAP::Lite::new: ()
   SOAP::Lite::new: ()
   SOAP::Data::new: ()
   SOAP::Data::new: ()
   SOAP::Lite::call: ()
   SOAP::Serializer::envelope: ()
   SOAP::Serializer::envelope: add_member SOAP::Data=HASH(0x1dba998) SOAP::Data=HAS
   H(0x1dbb948)
   SOAP::Data::new: ()
   SOAP::Data::new: ()
   SOAP::Data::new: ()
   SOAP::Data::new: ()
   SOAP::Data::new: ()
   SOAP::Transport::HTTP::Client::send_receive: HTTP::Request=HASH(0x1dc8a80)
   SOAP::Transport::HTTP::Client::send_receive: POST https://10.20.69.240:443/iCont
   Accept: text/xml
   Accept: multipart/*
   Content-Length: 933
   Content-Type: text/xml; charset=utf-8
   SOAPAction: "urn:iControl:LocalLB/Pooladd_member"
  -?xml version="1.0" encoding="UTF-8"?>
  -SOAP-ENV:Envelope
    xmlns:xsi="http://www.w3.org/1999/XMLSchema-instance"
    xmlns:namesp3="http://namespaces.soaplite.com/perl"
    xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/"
    xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"
    xmlns:xsd="http://www.w3.org/1999/XMLSchema"
    xmlns:namesp2="http://xml.apache.org/xml-soap"
    SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
    -SOAP-ENV:Body>
      -namesp1:add_member
        xmlns:namesp1="urn:iControl:LocalLB/Pool">
        -pool_names xsi:type="SOAP-ENC:Array"
          SOAP-ENC:arrayType="xsd:string[1]">
          -item xsi:type="xsd:string">N
            WG_WAP2
          -/item>
        -/pool_names>
        -members xsi:type="namesp3:IPPortDefinition"
          SOAP-ENC:arrayType="namesp2:SOAPStruct[1]">
          -item xsi:type="namesp2:SOAPStruct">
            -address xsi:type="xsd:string">10.200.16.51-/address>
            -port xsi:type="xsd:int">8080-/port>
          -/item>
        -/members>
      -/namesp1:add_member>
    -/SOAP-ENV:Body>
  -/SOAP-ENV:Envelope>
   SOAP::Transport::HTTP::Client::send_receive: HTTP::Response=HASH(0x20131c0)
   SOAP::Transport::HTTP::Client::send_receive: HTTP/1.1 500 Internal Server Error
   Connection: close
   Date: Fri, 12 Nov 2004 20:51:21 GMT
   Server: Apache
   Content-Type: text/xml; charset="UTF-8"
   Client-Date: Fri, 12 Nov 2004 10:57:45 GMT
   Client-Peer: 10.20.69.240:443
   Client-Response-Num: 1
   Client-SSL-Cert-Issuer: /C=--/ST=WA/L=Seattle/O=MyCompany/OU=1099665699/CN=local
   host.localdomain/[email protected]
   Client-SSL-Cert-Subject: /C=--/ST=WA/L=Seattle/O=MyCompany/OU=1099665699/CN=loca
   lhost.localdomain/[email protected]
   Client-SSL-Cipher: DHE-RSA-AES256-SHA
   Client-SSL-Warning: Peer certificate not verified
   Client-Transfer-Encoding: chunked
   SOAPServer: EasySoap++/0.6
   -SOAP-ENV:Envelope
           xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
           xmlns:xsd="http://www.w3.org/2001/XMLSchema">
   -SOAP-ENV:Body>
   -SOAP-ENV:Fault>
   -faultcode xsi:type="xsd:string">SOAP-ENV:Server-/faultcode>
   -faultstring xsi:type="xsd:string">
      Could not find element by name: address
   -/faultstring>
   -/SOAP-ENV:Fault>
   -/SOAP-ENV:Body>
   SOAP::Deserializer::deserialize: ()
   SOAP::Parser::decode: ()
   SOAP::SOM::new: ()
   SOAP-ENV:Server Could not find element by name: address
   SOAP::Data::DESTROY: ()
   SOAP::Parser::DESTROY: ()
   SOAP::Transport::DESTROY: ()
   SOAP::Transport::HTTP::Client::DESTROY: ()
   SOAP::Serializer::DESTROY: ()
   SOAP::Deserializer::DESTROY: ()
   SOAP::SOM::DESTROY: ()
   SOAP::Lite::DESTROY: ()
Do you know about why this error comes:
The parameter seems to be parsed in:
    -/item>
  -/members>
Thanks in advance for your help!
David
  • David, the signature for the add_members methods is the following
    void add_member(
          in String[] pool_names,
          in IPPortDefinition[][] members
    The idea is that you pass in a single dimensional array of pool_names and then a 2 dimensional array of members, 1 for each pool. This way you can add "n" different members for "m" pools. If the members parameter was a single dimensional array, it would add the list of members to all of the pools and more than likely that's not what would be wanted.
    So, looking at your code:
        SOAP::Data->name(members => [$node])->type("IPPortDefinition")
    it is passing in a single dimensional array for the members variable. Change your code to the following and you should be set.
    my @pool_list = @_;
      $member = {address => "10.200.16.51", port => 8080};
      @members = ( [ $member ] );  Create Array of Array
        SOAP::Data->name(pool_names => [@pool_list]),
        SOAP::Data->name(members => [@members])
    Check out this link (http://www.perldoc.com/perl5.8.4/pod/perllol.html) on perldoc.com about arrays of arrays. (I always get a chuckle out of this URL. The perl doc folks obviously have a sense of humor)...
    -Joe
