Moustafa_Abdelk's avatar
Moustafa_Abdelk
Jul 15, 2018
problem in certificate in win xp
hello , the customer has two cas sever and the F5 load balancing them , the certificate was axpired so he install another valid certificate , the issue : all OSs working fine with the new certificate but machines which it's os is Xp have certificate error
please , is there any solution to solve that issue ? is there any problem if i install the certificate manually or via active directory ?
thanks in advance Moustafa
  • Hi Moustafa, Could elaborate on the part of F5 on all this? Why is it related to F5? Thank you, Steve
