Quynh_Nguyen_Du's avatar
Quynh_Nguyen_Du
Jun 09, 2019
Problem for Monitor Pool member on LTM
Dear all,
I'm operating F5 7600 devices and i have upgraded successfull to BIG-IP 13.1.1 Build 0.0.4 Final verison
In this verison , i can't see option TCP, Icmp-gateway... in available monitor method.
Anyone has experience for this case? I need solution for this case.
Thank all.
  • Hi Quynh,
    Where in the GUI are you trying to set the monitor type? Are you trying to create a new monitor under Local Traffic ›› Monitors or somewhere else? When I navigate to that area in v13.1.1.3 and create a monitor I am able to see the options for TCP and Gateway ICMP when choosing the monitor "Type".
