problem f5.citrix_vdi.v2.3.0 iapp
Hello,
I recently updated the f5.citrix_vdi.v2.2.0 template to version f5.citrix_vdi.v2.3.0. After this i upgrade BIGIP from version 11.6 HF5 to 11.6 HF6. After the upgrade the config won't load. After running tmsh load sys config verify I get the following error message:
/Common/f5.citrix_vdi.v2.3.0 definition:556: warning: ["\n" has no meaning. Did you mean "\n" or "n"?][{\n.}]*
I cannot seem to figure out which \n is wrong in the iApp. Anyone a idea?
Regards,
- Fred_Slater_856Historic F5 Account
That is just a warning, so it should not stop config load. Do you get any other errors during config load?
- maltar_141221
No there a no other warnings during the config load.
I do see in /var/log/ltm
an 30 01:17:52 ic-lb1-2 notice mcpd[8046]: 01071431:5: Attempting to connect to CMI peer 172.17.0.1 port 6699 Jan 30 01:17:52 ic-lb1-2 err mcpd[8046]: 0107142f:3: Can't connect to CMI peer 172.17.0.1, TMM outbound listener not yet created
I assumed these errors were due to the warning in the config load. A number of articles specified a licensing issue. But if this were the case i should get an error during config load.
Also a ssl bug is mentioned in SOL16996. But this bug should be fixed in version 11.6 HF6.
Any more idea's where to look?
- Lucas_Thompson_Historic F5 AccountDon't specify verify, just load it and see what error happens. Licensing could yield a runtime error rather than a syntactic one.
