ReynaldoQ_14206's avatar
ReynaldoQ_14206
Feb 10, 2014
Problem connecting to virtual server
Hello,
I have a question. A telnet to a virtual server using port 8800 does not work but a telnet to a pool member works. Is there a setting in the virtual server preventing me from doing so?
Thanks.
  • have you tried to enable snat automap under virtual server?
    if still not working, can you post the configuration?
     tmsh list ltm virtual virtual_server_name
     tmsh list ltm pool pool_name
  • Nitass, Below is the config;
    ltm virtual vs_scrittura-ppe_7001 { destination 172.24.157.54:afs3-callback ip-protocol tcp mask 255.255.255.255 pool pl_scrittura-ppe_7001 profiles { fastL4 { } } snatpool snat_vs_scrittura-ppe }
    ltm pool pl_scrittura-ppe_7001 { members { 172.24.1.15:afs3-callback { priority-group 10 session monitor-enabled } 172.24.1.16:afs3-callback { priority-group 1 session monitor-enabled } } min-active-members 1 monitor http_scrittura-ppe_7001 }
  • i do not see any suspicious in the configuration. so, can you capture packet to see what the wrong is?
    e.g.
     tcpdump -nni 0.0:nnn -s0 -w /var/tmp/output.pcap port 7001 -v
