Tui_SAMURAI_368's avatar
Tui_SAMURAI_368
Apr 11, 2019
Problem BigIP (LTM) with Oracle DB 12cR1 & 12cR2
Hi, I am using Big-IP i4600 series (LTM) with Oracle database 11gR2 now, i can create the Oracle Monitor and using them to monitor Oracle database service, it's working find. But i try to use my Big-IP i4600 series with Oracle database 12cR1 & 12cR2, it's not working. Please help me or suggestion. thank you.
  • saying it is not working without any further configuration doesn't give us a whole lot to work with.
    easiest is to contact F5 support, they can work with you on your system on this.
    else you will need to share your configuration and show what exactly fails, some tcpdump output would be useful also then.
  • JG's avatar
    JG
    You can turn the debug mode on in your monitor and look into the monitor logs in directory "/var/log/monitors" to see where the failure occurred.
