problem between F5 and Websphere?
I seen this case ... F5 connect with database in IBM websphere and have persistence on
when I see cookie , it have 2 difference cookie , cookie persist (F5) and JSESSIONID
when I test , throughput and load balance is not good
at first i fix at connection pool in database but something still doesn't good enough
so i turn persistence off and use JSESSIONID alone then everything work fine
what difference between cookie persist and JSESSIONID ?
I think Websphere use JESSIONID and it interfere with cookie persist and process of F5
then it mean cookie persist (F5) and JSESSIONID can't work together.
am i thinking right?
- nitass
Employee
when I test , throughput and load balance is not good how did you test and measure throughput?
what difference between cookie persist and JSESSIONID ?i understand jsessionid is a cookie which is generated by server. bigip does nothing on it.
are you aware of this behavior?
sol7964: Persistence may fail for subsequent requests on Keep-Alive connections
http://support.f5.com/kb/en-us/solutions/public/7000/900/sol7964.html
just in case if you would like to try universal persistence but i think cookie insert persistence may be okay.
sol7392: Overview of universal persistence
http://support.f5.com/kb/en-us/solutions/public/7000/300/sol7392.html - kridsana
Cirrocumulus
i sent load using apache jmeter
one thing that bother my mind is why disable cookie persistence and use universal persistence (write iRule to use JSESSIONID instead of cookie_persist) , everything work fine. :(
I think about algorithm of Websphere to process order cookie that lookup for JESSIONID first make this problem, otherwise script that use in apache jmeter is bad. - nitass
Employee
one thing that bother my mind is why disable cookie persistence and use universal persistence (write iRule to use JSESSIONID instead of cookie_persist) , everything work fine. :( did you pass bigip's cookie, i.e. BIGipServer, in subsequent request in jmeter test plan? - kridsana
Cirrocumulus
sorry i don't know script in jmeter. so i don't know why i switch persistence mode and then it work.
now i think about your question. it might because script jmeter. - giltjr
Are you actually using the F5 to load balance directly to WebSphere? Or is the F5 frontend'ing IBM's HTTP server?
The JSESSIONID for WebSphere has multiple parts. The first part is a unique session id for that user/session. Then there can be 1 or more additional parts that have a unique ID for each WebSphere Server. The additional parts are separated by a colon.
Because of how our system is setup we use a combination of the JSESSIONID and then a pool name to create a universal persistence record.
We have multiple applications with separate pools that all share the same same session id. So we break out the session ID and append it with the pool name for that specific application.
