daboochmeister's avatar
Aug 10, 2017
Priority group activation - what if lowest priority group has less servers than the "less than" setting?
Say we have the following setup:
Priority group 2: 4 servers Priority group 1: 2 servers Activation: less than 3 servers
How will this behave when we lose 2 servers from priority group 2? At that point it will meet the "less than 3 servers" criteria to trigger pg1 ... but that group ALSO has < 3 servers, right when it gets activated. Will traffic at that point nevertheless be flowing to the remaining 2 servers in pg2, AND to the 2 servers in pg1?
Thx!
  • Further if we have an even lower priority group with 1 server (so:
    • PG10 = 4 servers
    • PG5 = 2 servers
    • PG1 = 1 server
    with activation set to "< 3").
    When 2 servers fail in PG10, and PG5 is activated - since PG5 has less than 3 servers active right from the start, will PG1 also be activated?
  • Hi,
    First scenario :
    • Activation: less than 3 servers
    • PG 2: 4 servers*
    • PG 1: 2 servers
    Based on this official article "If the number of available members in the highest priority group drops below the minimum number, the BIG-IP system also distributes traffic to the next higher priority group"
    So 2 servers in PG2 goes down, traffic will be load balanced between the 2 remaining servers in PG 2 and both servers in PG 1.
    You can also look at the following video from min 10 to the end it demonstrates this scenario.
    https://www.youtube.com/watch?v=wzyhCh-2NqY
    Second scenario :
    • PG10 = 4 servers (2 down 2 UP)
    • PG5 = 2 servers (2 UP)
    • PG1 = 1 server (UP)
    When 2 servers fails in PG10, the less than 3 servers active in the highet priority group (PG10) is matched, the load balancer will look to the next highest priority group to have at least 3 servers active. At this point, PG10 has 2 servers UP and PG5 has 2 UP (a total of 4 servers are UP) then PG1 will not receive any traffic. If we loose all PG10 servers then PG5 and PG1 will receive traffic.
    Regards
  • Hi
    Priority group is simple.
    The pool enable as much priority groups as required to satisfy defined minimum requirement.
    If PG10 doesn't have enough available servers to satisfy minimum of 3 servers, pool will activate all members in PG5
  • Thank you guys - that's the key concept i didn't understand, that "less than 3" for activation isn't evaluated against a group per se, it simply means that at all times it's going to activate groups as needed until at least 3 servers are up. That's unambiguous.
