Angelo's avatar
Angelo
Feb 20, 2013
print servers load balancing
Hi
I got a VS to load balance two print server. it's a fastl4 VS that works i can access the print server on port 445. the problem i have is that once i access the VIP on port 445 i click on a printer it doesn't install the printer it just pops out a error. i have open all port to the VS for testing so i'm not sure what the problem is...
  • Hey Angelo. Can you confirm the print servers have a route back to your client(s) via the F5?
  • uni's avatar
    uni
    Angelo, could you post the config for your virtual server?
  • Angelo's avatar
    Angelo
    I got it working this is the config
    VS configuration on F5
    ltm virtual vs_bc_printing {
    destination 10.237.0.1:any
    ip-protocol tcp
    mask 255.255.255.255
    partition BRC
    persist {
    /Common/source_addr {
    default yes
    pool pool_bc_citrix_printers
    profiles {
    FastL4_Print { }
    rules {
    LB_logging
    snat automap
    translate-port disabled
    vlans-disabled
    In conjunction to this a loopback adapter will need to be created on the Wintel server (no reboot is required for this setup and the commands must be run to activate the adapter..)
    Click Start, select Run and enter hdwwiz to start the Hardware Installation Wizard
    When the Wizard has started, click Next
    Select 'Install the hardware that I manually select from a list (Advanced)', click Next
    Select 'Network adapters', click Next
    Select 'Microsoft' & 'Microsoft Loopback Adapter', click Next
    1. Right click network icon in the systray and click Network and Sharing Centre
    2. Click Change adapter settings
    3. Right-click the new loopback adapter and select Properties
    4. Un-check all items except Internet Protocol Version 4 (TCP/IPv4)
    5. Select Internet Protocol Version (TCP/IPv4), click Properties and configure the IP address to be the same as the Virtual Server (VIP), with a full subnet mask of the individual IP e.g. 255.255.255.255. Do not add a gateway.
    6. Click OK on the TCP/IP popup window, then click Close on the Local Area Connection window to save the new settings For Windows 2008, its not necessary to modify the interface metric on the advanced tab and should be left set to Automatic
    8. Rename the loopback "Loopback" from localareaconnection 2
    9. Run the following in a command prompt:
    netsh interface ipv4 set interface "Local Area Connection" weakhostreceive=enabled
    netsh interface ipv4 set interface "Loopback" weakhostreceive=enabled
    netsh interface ipv4 set interface "Loopback" weakhostsend=enabled
    10. Now repeat the above process for all other Windows 2008 real servers
  • I've seen a couple of posts similar to this regarding load balancing print servers, and they all seem to indicate that the loopback address is required in order for it to function as expected. However looking at your configuration for your virtual server you do not have "translate-address disabled", so is it actually required?
    Am I completely off base here? I only ask because a colleague was looking to accomplish something similar.
