Laudec_107382's avatar
Laudec_107382
Nov 25, 2008
Preserving Src IP in TCP Packet with Snat
I have a client that needs to have incoming connections loadbalanced. Due to the nature of the deployment and architecture, the BigIPs were deployed in a one-arm installation. The clients only need to be loadbalanced. The servers are not HTTP servers.
Is there an irule that will preserve the client IP address, even if the return path bypasses the BigIP, they only need to be loadbalanced.
  • hoolio's avatar
    hoolio
    If you're able to make changes on the web servers, you could potentially use nPath routing to accomplish this. You can get more info on this in the LTM Soltuions Guide for your version. Here is the section from 9.4.3:
    Configuring nPath Routing
    https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm_sol_guide_943/sol_npath.html
    Aaron
  • Hi,
    Unfortuanately the loadbalanced machines are linux based systems, that are running a custom app for ATM tellers..so no web servers or interfaces. The app needs to be able to see the source IP in order to facilitate transactions.
