TheGonkulator_3's avatar
TheGonkulator_3
Nov 30, 2018
Preserve original sender IP for non-HTTP traffic?
I'm load balancing syslog-ng traffic on UDP 514. I have to use SNAT automap in my environment and that is obsuring the original sender IP. syslog-ng needs that to sort the traffic by device. If this were HTTP traffic, I'd use x-forwarded-for to accomoplish this. But it's UDP 514.... Does anyone know how I can preserve the original sending IP without disabling SNAT automap?
  • Hi
    I see you are trying to send syslog to pool members. If the pool members doesn't need to do bidirectional interaction, you can just disable snat translation on the pool level.
