Power Supply and Fan Status are not visible in CLI
Hello Canan.
You could be facing some bug or matching some specific condition.
https://cdn.f5.com/product/bugtracker/ID720104.html
https://support.f5.com/csp/article/K18802953
I recommend you in future questions to provide more information about your environment (like release, platform or command output), this could help us to understand what your issue is.
Anyway, if I were you I would try to search in your device stats (psu, fan) if this information is represented correctly or not. I don't remember exactly the table name, just search for it with this command:
tmctlAn example:
tmctl -w 300 blade_temperature_status_statRegards,
Dario.
Hi Dario,
Thank you for your reply, I try to search stats with the commands you wrote. But there is no information about the FAN or PSU on the table. As you stated it could be a bug or something.
