Canan
Dec 10, 2020Power Supply and Fan Status are not visible in CLI
Hi everyone, I want to see the chassis power supply and chassis fan status of a device from CLI, using "tmsh show sys hardware" command. But there is no information about the power supply and f...
jaikumar_f5
Noctilucent
Dec 17, 2020I suspect you maybe on Guest, can you confirm that by running this below command,
tmsh show sys hardware | grep -A1 PlatformIf it says Guest, you may not able to see power/fan status. Only if its a hardware, you would see.
Also if it was a hardware, I'm positive you should have atleast seen Down or something else. But since you get blank, I'm suspecting it could be a guest machine.
- CananDec 26, 2020
Thank you for your attention but it is hardware appliance.
- jaikumar_f5Dec 28, 2020
Noctilucent
Can you open a support case and keep us posted too.
