Canan
Dec 10, 2020Power Supply and Fan Status are not visible in CLI
Hi everyone, I want to see the chassis power supply and chassis fan status of a device from CLI, using "tmsh show sys hardware" command. But there is no information about the power supply and f...
Samir
MVP
Dec 11, 2020Can you check if you are running LB device on VM or vCMP guest?
