Post Upgrade test for ASM and APM?
Hi all,
We have two F5 boxes in HA and we are using LTM, ASM and APM modules. Currently boxes are running on 13.1.0.3 TMOS version and we planned to upgrade to 14.1.2. After upgrading the boxes, I am confused what post-upgrade tests must be done for ASM and APM in order to make sure to continue with UPGRADED VERSION. I have no knowledge on ASM and APM modules.. can someone help me with this??
-Thanks in Advance.
- iaine
Nacreous
Hi
For each module I would write a couple of test cases that show the expected behaviour of the modules.
For APM, I would setup a test that uses the configured APM policy(s) - so for instance, prove that authentication works, does the webtop display, click on an icon - do you get to the desired service. If you have multiple types of service, show that they all work (rdp, portal icon, network vpn etc). It all depends on what functionality you are using.
For ASM - again, according to the config of your policy. Can you make a successful legitimate request to your site. Can you make an illegitimate request to your site, does the policy successfully block the request? Are alerts firing as you expect. Again, it all depends on what you have configured in your policy for you to test against. Some organisations re-run an independent PEN test after an upgrade to verify the platform.
If you test both pre and post upgrade and they check out then you can then get business sign off for the upgrade.
