Kapil_Sharma_61's avatar
Kapil_Sharma_61
Dec 12, 2005
post fields and characters
I am tring to send a post field to the backend server through BigIP.
The packet looks like (from the client side):
data=6jetmBWyLhqjQlC7UCyyYnO/02u9v/GyOmmWsUA7x8hUa57YDDXKJZ6BtSSkMQy7ZNVBQvc+YgpFDy70UufBRd3HjUKlI1P4Ic7aMJ0r
This same packet gets converted into the following on the BigIP:
data=6jetmBWyLhqjQlC7UCyyYnO%2F02u9v%2FGyOmmWsUA7x8hUa57YDDXKJZ6BtSSkMQy7ZNVBQvc%2BYgpFDy70UufBRd3HjUKlI1P4Ic7aMJ0r6
As you can see,
the character "/" gets replaced by "%2F"
The character "+" gets replaced by "%2B"
Can you please help me with this scenario!!
I am using the following irule on the bigip to display the post field:
when HTTP_REQUEST_DATA {
set payload [HTTP::payload [HTTP::payload length]]
log "the payload is $payload"
HTTP::release
Thanks,
kapil
  • BIG-IP will not do any HTML escaping conversions within the payload unless you specifically do so within an iRule.
    How exactly are you posting this information? If BIG-IP is presenting the data with the given HTML escapes then odds are it's your client that is the culprit.
    -Joe
  • unRuleY_95363's avatar
    unRuleY_95363
    Historic F5 Account
    You can also try the URI::decode function on the BIG-IP to convert it back...
