gerald_wegener_
Aug 28, 2006Possible to use SWITCH with variable
Is it possible to use switch to do the following using variables?
I've been trying for a while but can't get it to work using SWITCH.
X = some random number say 50
A =10
B =4
C =6
if { $X > $A } {
pool pool01
if { $X <= $B } {
pool pool02
if { (($X > $B) and ($X <= $A)) } {
pool pool3
Thank you for your help.
- Deb_Allen_18Historic F5 AccountI'm not sure "switch" is the right command for the job...
"switch" is useful when you want to react to equality with known values or patterns, but since you are instead evaluating inequalities, I think what you have is more appropriate.
HTH
/deb - gerald_wegener_
I didn't see a way I could use SWITCH but wanted to double-check. Thank you.
