touchring_93818
Jul 21, 2009Possible to first authenticate against RADIUS, and if no response, failover to AD.
Hi, my user is using Firepass SSL, and I would like to find out if it is possible to configure Firepass SSL to authenticate against RADIUS, and if the RADIUS Server does not respond or is down, failover to AD. Thanks.
- psilvas
Altostratus
in Users>Groups>Dynamic Group Mapping you should be able to create a Group Mapping sequence (fallback to authenticate against), then in Master Group Mapping Table, map the RADIUS/AD group to a FirePass group. hope that helps.
ps - touchring_93818
Thank you. - Noppadon_Panyar
how about if the first radius doesn't down but it doesn't has that user on its database, then firepass try requesting on second radius server? is it possible? please advice.
