Bob_10976's avatar
Bob_10976
Jan 26, 2011
Possible Syntax issue with HTTP::Cookie iRule
Hello all..
I have a working iRule in place and I need add to it, but it seems I'm getting some type of Syntax error.
The current iRule looks like this and as I said appears to work fine:
when HTTP_RESPONSE {
if { [HTTP::cookie exists "ASP.net_SessionID"] } {
HTTP::cookie secure "ASP.net_SessionID" enable
if { [HTTP::cookie exists ".ADAuthCookie"] } {
HTTP::cookie secure ".ADAuthCookie" enable }
I'm simply wanting to add a third cookie reference:
if { [HTTP::cookie exists "RS_User"] } {
HTTP::cookie secure "RS_User" enable }
When I do I get the following errors:
Line 8: [command is not valid in the current scope] [if {HTTP::cookie exist “RS_User”]}{
Line 10: [command is no valid in the current scope][}]
Am I missing something here?
Thanks,
Bob
  • You have an extra "}" above your final if statement. Give this a shot.
    That was originally there to close the HTTP_REQUEST event. Looks like an additional was was correctly created at the end of the new rule but the original wasn't removed.
