Jeremy_C_Russel's avatar
Jeremy_C_Russel
Nov 13, 2011
Possible issue with an iRule
Greetings all.
I wanted to get some eyes on this particular rule I've setup. The premise is to take urls in the form of http://string.domain.com or http://www.string.domain.com, capture "string" and redirect to a new url, http://www.domain.com/SomeURI?a= where we append the captured string.
I've tested this and it works fine, but for some folks its errors.. in IE, is give them a 404 and in Firefox, it's complaining of a "Connection Reset".
I can't see anything as to why this would be caused.
if { [regexp {www} [HTTP::host]] } {
scan [HTTP::host] {%[^.].%[^.].%s} www host dom
scan [HTTP::host] {%[^.].%s} host dom
if { not [regexp {domain|www|wsecure|ssl} $host] } {
log local0. "Caught a MS host $host, redirecting..."
HTTP::redirect "https://www.domain.com/MS/RedirectMS?site=hub&value=$host"
  • not sure if adding log command is helpful in troubleshooting.
    e.g.
    [root@ve1023:Active] config  b rule myrule list
    rule myrule {
            set www ""
            if {[regexp {www} [HTTP::host]]} {
            log local0. "[IP::client_addr]:[TCP::client_port]|[HTTP::host]|[HTTP::uri]|$www|$host|$dom"
            if {not [regexp {domain|www|wsecure|ssl} $host]} {
    [root@ve1023:Active] config  curl -I http://abc.com/test
    HTTP/1.0 302 Found
    Location: https://www.domain.com/MS/RedirectMS?site=hub&value=abc
    Server: BigIP
    Connection: Keep-Alive
    Content-Length: 0
    Nov 14 00:40:24 local/tmm info tmm[4766]: Rule myrule : 172.28.65.150:53712|abc.com|/test||abc|com
    Nov 14 00:40:24 local/tmm info tmm[4766]: Rule myrule : Caught a MS host abc, redirecting...
    [root@ve1023:Active] config  curl -I http://www.abc.com/test
    HTTP/1.0 302 Found
    Server: BigIP
    Content-Length: 0
    Nov 14 00:40:31 local/tmm info tmm[4766]: Rule myrule : 172.28.65.150:53713|www.abc.com|/test|www|abc|com
    Nov 14 00:40:31 local/tmm info tmm[4766]: Rule myrule : Caught a MS host abc, redirecting...
    additionally, i think it would be great if we can avoid using regex. you know it is cpu intensive.
  • hoolio's avatar
    hoolio
    If you're seeing connection resets with an iRule, check the /var/log/ltm file for runtime TCL errors.
    However, as Nitass said, you should be able to rework this iRule with string pattern matching to avoid the high CPU costs of regexes. I'm not exactly sure what logic you're trying to implement, but here's a stab at it:
     Remove www. from the host header value if it is present
    set host [string map {www. ""} [string tolower [HTTP::host]]]
    log local0. "[IP::client_addr]:[TCP::client_port]: Parsed $host from [HTTP::host]"
    switch $host {
    "domain" -
    "wsecure" -
    "ssl" {
    log local0. "[IP::client_addr]:[TCP::client_port]: Matched part of $host, redirecting"
    http://devcentral.f5.com/wiki/iRules.switch.ashx
    http://devcentral.f5.com/wiki/iRules.getfield.ashx
    Aaron
  • Aaron,
    nice irule. 🙂
    by the way, should we also remove top-level domain?
    e.g.
    rule myrule {
        scan [string map {www. ""} [string tolower [HTTP::host]]] {%[^.]} host
        switch $host {
            "domain" -
            "wsecure" -
            "ssl" {
                 do something
            default {
    HTTP/1.0 302 Found
    Server: BigIP
    Content-Length: 0
    Nov 14 07:29:34 local/tmm info tmm[4766]: Rule myrule : 172.28.65.150:46973: Parsed abc from www.abc.com
    Nov 14 07:29:34 local/tmm info tmm[4766]: Rule myrule : 172.28.65.150:46973: Matched part of abc, redirecting
    HTTP/1.0 302 Found
    Server: BigIP
    Content-Length: 0
    Nov 14 07:29:43 local/tmm info tmm[4766]: Rule myrule : 172.28.65.150:46974: Parsed abc from abc.com
    Nov 14 07:29:43 local/tmm info tmm[4766]: Rule myrule : 172.28.65.150:46974: Matched part of abc, redirecting
  • hoolio's avatar
    hoolio
    Good catch Nitass. I was going to use getfield to parse it, but forgot about it. scan should be able the same efficiency.
    Aaron
  • Thanks for the replies. I do think an error in other parts of the rule was the issue. I have taken your advice though to reduce my use of regexp. Is there a point at which the number of elements in a switch statement starts to be of concern?
  • Hi Jeremy,
    One of the MVP's (smp), did a benchmark test on this and posted his results here:
    Switch or Class?
    There are varying suggestions on it, but IMO (as you will see on a benchmark 100K connect test) while there is a performance difference, unless you are seriously pinching CPU cycles you should go with which ever is easiest for you to maintain (but be aware of the caveats of each like the ones that Arie noticed in smp's post).
    Hope this helps.
