MvdG's avatar
MvdG
Icon for Cirrus rankCirrus
May 14, 2021
Poor upload speed BIG-IP Edge client
Hi All,
I have configured APM Network Access with BIG-IP Edge client and this works fine.
We can connect, are authenticated and access internal resources. No problem there.
But we found out upload speeds from the Edge client are very low.
We can download with 4 MB/s, but can only upload with 700 KB/s.
We have tried several things, but none of them worked.
- Disable compression in the Connectivity and Network Access profile
- Enable DTLS
- Used the TCP-F5-Progressive profile on the VS
APM version:
5.1.2.1
Client version
Build version. . . . . . : 7211,2021,107,1217
API version. . . . . . . : 7211,2021,107,1217
We need to create traces to see what is going on, but maybe one of you have sees this before and got is solved.
Your tips and tricks are appreciated.
Regards,
Martijn
  • Hi,
    Customer had a Client Traffic Classifier profile with Client Rate Classes configured on the Network Access configuration.
    As a test, we removed this profile from Network Access and now the upload speed is 2.5 MB/s.
    So it seems to have something to do with this Client Traffi Classifier. Customer wants to limit the throughput for clients.
    Regards,
    Martijn
  • Check the Edge Client article for investigating issues:
    https://support.f5.com/csp/article/K17421
    Also you can do tcpdump on a connectivity profile that is used by the VPN virtual server:
    https://support.f5.com/csp/article/K13301
