Pool members goes down where as application is running
We are facing a problem.
There are about 40 pools defined in LTM and each have 2 or 3 members. All of them are monitored on TCP-halfopen monitor which monitors pool members on the bases of TCP port.
Only 1 pool which have 3 members goes down up down up simultaneously after one two days. Not one member but all three. I get informed by email notifications. But Application experts handling servers says that application is running and it didn't stopped at that time.
Now i am confused why only this one pool goes down and gives fake alarms? Or its possible that application is running but as this application have a lot of load now a days that is why it doesn't respond to monitoring of F5 that is why F5 mark it down?
- StephanManthey
Nacreous
Hi Muhammad,
this pool is monitored as well via tcp_half_open only, if I understood your question right. You can see the pool member toggling as well in /var/log/ltm? I would recommend to run a trace while observing the issue:tcpdump -nnni 0.0 -s 0 -e 'host and (host or host )'Just replace "bigip_self_ip" with the serverside self IP of the BIG-IP you are running the trace on (as it is used for healthchecking) and the "node_0(1|2)" by the pool member IPs.
The tcp_half_open should show a SYN sent by BIG-IP, SYN-ACK response from node, followed by RESET from the BIG-IP. Perhaps your server folks are running an IDS/IPS? Did you already try to use an increased monitoring interval? I would be interested in your findings. What TMOS version are you on? Thanks, Stephan
