Josh_Abaire's avatar
Josh_Abaire
Dec 14, 2012
Pool member not disabling despite failed monitor
My pools members are still showing as available even when the monitor should be failing. I first had it just look for 200 OK and it wasn't working so added 403 as a disable string and it still doesn't work. Am I missing something or is this a bug?
Ltm::Pool Member: dcentral821-443 10.16.130.165:443
Status
Availability : available
State : enabled
Reason : Pool member is available
ltm pool dcentral821-443 {
members {
10.16.130.164:https {
session monitor-enabled
10.16.130.165:https {
monitor dcentral821-443
ltm monitor https dcentral821-443 {
cipherlist "DEFAULT:+SHA:+3DES:+kEDH"
compatibility "enabled"
defaults-from https
destination *:*
interval 5
recv "200 OK"
recv-disable "403"
send "GET /wsp/httpStatus.jsp HTTP/1.1\r\nHost: dcentral821.intra.aexp.com\r\n\r\n\r\n"
time-until-up 0
timeout 16
curl -kI https://10.16.130.165/wsp/httpStatus.jsp
HTTP/1.1 403 Forbidden
Date: Fri, 14 Dec 2012 23:07:03 GMT
Server: IBM_HTTP_Server
$WSEP:
Set-Cookie: JSESSIONID=00002Sq11SBcG6Nb-dKSFLk-GWh:17b9prvpt; Path=/
Expires: Thu, 01 Dec 1994 16:00:00 GMT
Cache-Control: no-cache="set-cookie, set-cookie2"
Content-Type: text/html;charset=ISO-8859-1
Content-Language: en-US
  • hoolio's avatar
    hoolio
    Hi Josh,
    Which LTM version are you testing on?
    It's unlikely, but is there any payload in the response that might be matching the 200 OK receive string?
    Else, can you enable debug on bigd and check the /var/log/bigdlog output file? See this wiki page for details on enabling bigd.debug:
    https://devcentral.f5.com/wiki/AdvDesignConfig.TroubleshootingLtmMonitors.ashx
    tmsh modify sys db bigd.debug value [enable | disable]
    And thanks for your replies to the other posts in the forums.
    Aaron
  • I thought about something in the response. Since some monitors are setup to look for just the HTTP code, and 200 might be matched elsewhere. I posted the result from curl, shouldn't that be all there is in the response? I'll check a verbose output to see if I'm missing anything.
    I've never worked with debug. I'll check it out later. Thanks for the suggestion.
  • The response to a request made via curl and a request made via an LTM monitor should be essentially similar, but it's worth enabling the bigd logging and perhaps getting tcpdumps for both the curl and monitor requests, in case there is something different happening.
    While it is possible that you might have an errant mach on the string '200', I doubt that your are going to get an arrant match on '200 OK'.
