pool load balancing method.
Hello, In my scenario there are 2 nodes(A & B) in pool with load balancing method round robbin. I had disabled the application on server A but stil the traffic is not going to server B instead it is still going to server A.
So for this which load balancing method i should select.
Thank you.
- IheartF5_45022
Nacreous
You need to have a suitable monitor applied to your pool so that when you disable the application on 1 pool member, LTM marks the pool member down. Start with tcp, but in general the more specific you can make the check to your protocol the better ie. HTTP monitor for http traffic.
- Vivek_Padale_16
Hello, thanks for the response.
I am having http monitor in my pool
Thank you
- IheartF5_45022
Nacreous
So when you disable the application on server A, is it being marked down?
If not, you need to adjust the check so that when you disable the application, the monitor picks it up.
- Vivek_Padale_16
Hello,
I applied http monitor with the application url in send string in it.....n then it is showing down.
Thank you
- IheartF5_45022
Nacreous
Do you have "Action on service down: none" set? If so, requests on keepalive connections may continue to go to the server that is down, even after it is marked down. To change this behaviour, you should change that setting to "reselect".
