pool is down becouse the parent node level monitor is failing
Hello,
We have selected icmp as default health monitor for node . We are using tcp half open as pool level monitor and pool monitor is up but pool and vs is down due to the parent node health monitor is failing (icmp is blocked in FW) is there any way to restrict node health check from pool or vs configuration.
- nathe
Cirrocumulus
Mikegray, afraid not as monitors' status are propogated from child to parent.
You're option is to remove ICMP from the node's health monitor. The node will be Unknown and then you're pool member should be marked up based on the pool monitor.
Hope this helps,
N
