cnorgay_17044's avatar
cnorgay_17044
Jan 18, 2008
pls: help .....
hi gurus
convert the below from apache syntax to irules:::.thanks alot
apache syntax:
RewriteEngine on
RewriteRule ^/$ https://aaaa.bbbb.com/hp/index.php?id=30&L=0 [NC,R,L]
RewriteCond %{REQUEST_URI} ^/favicon.ico$
RewriteRule ^(.+)$ https://mylife.bbbb.com/$1 [NC,P,L]
RewriteCond %{REQUEST_URI} !^/favicon.ico$
RewriteRule ^(.+)$ https://www.cccc.com/$1 [NC,P,L]
  • hoolio's avatar
    hoolio
    Hello,
    The first rule is rewriting requests to /favicon.ico to https://mylife.bbbb.com/favicon.ico. The net effect appears to be changing the Host header value to mylife.bbbb.com.
    Here are the meanings of the rewrite flags you have listed (from the apache mod_rewrite man page Click here😞
    NC - No Case (case insensitive comparison)
    P - send the request to the Proxy module
    L - Last (no other evaluations should be done)
    The second rule is redirecting any requested URI which doesn't match /favicon.ico to https://www.cccc.com/$1, where $1 is the backreference from the regex (the full URI). The net effect is that the Host header is rewritten to www.cccc.com.
    Here is an equivalent iRule:
    Per a note on the mod_rewrite page, the pattern is compared against the URI without the query string. In iRules you can use the command HTTP::uri to get the rule URI including the query string (/path/to/file.txt?param=value). HTTP::path returns just the path and object (/path/to/file.txt).
        Check requested URI (set to lower case)
       switch [string tolower [HTTP::path]] {
          /favicon.ico {
              Request was for the favicon.ico so rewrite Host header to mylife.bbbb.com
             HTTP::header replace Host mylife.bbbb.com
          default {
              Request wasn't to /favicon.ico, so rewrite Host to www.cccc.com
             HTTP::header replace Host www.cccc.com
    For details on iRule commands, you can check the iRule wiki pages:
    iRules - (Click here)
    events - (Click here)
    switch - (Click here)
    HTTP::header - (Click here)
    HTTP::redirect - (Click here)
    Aaron
