Ping Federated Health Monitor
The Ping administrator gave me a URL to use for testing pool members. https://:9031/pf/heartbeat.ping The results should be "OK". Is it possible to create a HTTPS based monitor using port 9031?
- nitass
Employee
health monitor uses pool member port unless you specify the port number.
- nag_54823
if you want to monitor pool member on different port then u can use dest *.portnumber
- nag_54823
Hi Rob,
No it's not part of send string. there is a seperate setting in every monitor. u can check with "b monitor https list"
b monitor https list monitorroot type https { defaults from none interval 5 up interval 0 timeout 16 time until up immediate dest : ignore down response disable enable is read only partition Common cert none cipherlist "DEFAULT:+SHA:+3DES:+kEDH" compatibility "enabled" key none password none recv disable none recv none send "GET /\r\n" username none }
- nitass
Employee
e.g.
config root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm monitor https myhttps ltm monitor https myhttps { cipherlist DEFAULT:+SHA:+3DES:+kEDH compatibility enabled defaults-from https destination *:* interval 5 ip-dscp 0 recv "404 Not Found" send "GET /pf/heartbeat.ping\r\nHost: \r\nConnection: Close\r\n\r\n" time-until-up 0 timeout 16 } root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 200.200.200.101:9031 { address 200.200.200.101 session monitor-enabled state up } } monitor myhttps } trace [root@ve11a:Active:In Sync] config ssldump -Aed -nni 0.0 port 9031 -k /var/tmp/localhost.key New TCP connection 1: 200.200.200.11(58764) <-> 200.200.200.101(9031) 1 1 1397586345.7759 (0.0062) C>SV3.1(514) Handshake 1 2 1397586346.0500 (0.2741) S>CV3.1(81) Handshake 1 3 1397586346.0500 (0.0000) S>CV3.1(1052) Handshake 1 4 1397586346.0500 (0.0000) S>CV3.1(4) Handshake 1 5 1397586346.0527 (0.0027) C>SV3.1(134) Handshake 1 6 1397586346.0527 (0.0000) C>SV3.1(1) ChangeCipherSpec 1 7 1397586346.0527 (0.0000) C>SV3.1(32) Handshake 1 8 1397586346.2393 (0.1865) S>CV3.1(1) ChangeCipherSpec 1 9 1397586346.2393 (0.0000) S>CV3.1(32) Handshake 1 10 1397586346.2406 (0.0012) C>SV3.1(69) application_data --------------------------------------------------------------- GET /pf/heartbeat.ping Host: Connection: Close ---------------------------------------------------------------
