Physical Network Interface LED is Amber
Dears,
My Big-IP Physical Network Interface LED is Amber but its working perfectly and there is no error in the host logs what may cause this ????
- MvdG
Cirrus
What is your hardware type?
I would check link speed and duplex settings on the interface. Maybe there is a miss match.
Regards, Martijn
- AhmedGalal219_3
i5800 , Auto speed, Full duplex in both sides
- MvdG
Cirrus
Check:
Looks like Amber is OK.
Regards, Martijn
- Martijn_144688
Regards, Martijn
- AhmedGalal219_3
- Martijn_144688
Check:
Regards, Martijn
