Permanent installation of Big IP edge client automatically via connectivity profile.
Hi is there any possibilities of permanently installing the Big IP edge client via connectivity profile. Because currently when we try to access the application(via app tunnel and network access) with admin rights its working fine, but when we logout and try without admin access the application is inaccessible, but when we download and install the edge client manually in client PC with admin rights we are able to access the application even if we have logged out and login without admin rights. So is there any possibility to distribute the Big IP edge client via connectivity profile so it will be installed permanently in client PC. Please help thanks in advance.
- Saravanan_M_K
Employee
No. It is not possible to do a fresh installation of edgeclient using connectivity profile. Instead you can provide a link to the BIGIP Edgeclient setup file to the end user (either hosted on BIGIP itself or on other servers) so that he can download and install it manually. Alternatively, if the end user is using corporate domain joined PCs/laptops, you can force the installation of edgeclient on the domain users PC/laptop using appropriate GPO on Active Directory.
