orangepeelbeef_'s avatar
orangepeelbeef_
May 21, 2009
perl create pool & monitor problem
Hi there, I'm trying to get a perl pool creator working properly. Actually Everything is working except for the monitor definition, and when I try to add a monitor, I get back a 500 error from the bigip.
Here's the code snippet
 $Pool = SOAP::Lite
 -> uri('urn:iControl:LocalLB/Pool')
 -> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
 eval { $Pool->transport->http_request->header
 'Authorization' =>
 'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')
  Add the default HTTP monitor to a pool
 sub addmonitor($) {
 my $pool = shift;
 $soapResponse = $Pool->set_monitor_association(
 SOAP::Data->name(monitor_associations =>
 \SOAP::Data->name(MonitorAssociation =>
 \SOAP::Data->value(
 SOAP::Data->name(pool_name => "$pool"),
 SOAP::Data->name(monitor_rule =>
 \SOAP::Data->value(
 SOAP::Data->name(type=>"MONITOR_RULE_TYPE_SINGLE"),
 SOAP::Data->name(quorum=> 0),
 SOAP::Data->name(monitor_templates=>"http")
 &checkResponse($soapResponse);
soap envelope
portal-qaMONITOR_RULE_TYPE_SINGLE0http
 SOAP::Transport::HTTP::Client::send_receive: HTTP::Response=HASH(0x89bb5d0)
 SOAP::Transport::HTTP::Client::send_receive: HTTP/1.1 500 Internal Server Error
  • Yeah, you need to make sure you put brackets around variables when they need to be coerced into arrays.
    -Joe
