Geoff_Littlewoo's avatar
Geoff_Littlewoo
Jun 27, 2008
Passing through SSL to Exchange 2003 and re-direct script
Using BIG-IP 1500 and have created a VS to connect to a Microsoft Exchange 2003 to run the Browser based inteface.
Although the connection goes through the F5 and picks up the correct SSL certificate associated with the VS but, then does not re-direct using the Re-direct script on the Exchange server.
So the issue being is, what is needed to be created on the F5 to allow SSL traffic get re-directed to the IIS folder /EXCHANGE .
I can create a NON 443 VS .i.e. port 80 and it connects happily to the Web Mail interface on the Exchange server. As soon as I put this through the 443 VS re-direction does not work.
Hope this makes sense.
