OWA 2010: "Options" button does not work.
We are piloting a v11.2.1/Exchange 2010 iApp deployment (we currently run v10.2 in production) and have noticed a problem with OWA 2010. Most of the time, when behind the 11.2.1 load balancers, when a user clicks on the "Options" button in the upper-right hand part of OWA, the link does not work. The browser continues to spin, but the menu never appears.
We have not been able to reproduce this behavior on our 10.2.1. platform.
Any ideas?
Thanks.
- mikeshimkus_111Historic F5 AccountHi Josh, which version of the Exchange iApp are you using? Have you taken a client side capture of the HTTP traffic? If so, can you see which request is getting hung up?
Can you post a sanitzed copy of your combined persistence iRule here?
thanks
Mike - Josh_41258
Mike,
We are running f5.microsoft_exchange_2010_cas.2012_06_08.
I have not taken a client side capture yet, but I can do that if we need to.
Here is a copy of the iRule:when HTTP_REQUEST { OAB and Autodiscover do not require persistence. switch -glob -- [string tolower [HTTP::path]] { "/microsoft-server-activesync" { Direct all ActiveSync clients to a common pool; use Auth header value if it exists (Basic auth only, which is the default); otherwise we fall back to client IP if { [HTTP::header exists "APM_session"] } { persist uie [HTTP::header "APM_session"] 7200 } elseif { [HTTP::header exists "Authorization"] } { persist uie [HTTP::header "Authorization"] 7200 } else { persist source_addr } pool FC-EX2010-DC1-CAS_as_pool COMPRESS::disable CACHE::disable return } "/owa*" { Outlook Web Access if { [HTTP::header exists "APM_session"] } { persist uie [HTTP::header "APM_session"] 7200 } else { persist cookie insert } pool FC-EX2010-DC1-CAS_owa_pool return } "/ecp*" { Exchange Control Panel. if { [HTTP::header exists "APM_session"] } { persist uie [HTTP::header "APM_session"] 7200 } else { persist cookie insert } pool FC-EX2010-DC1-CAS_owa_pool return } "/ews*" { Exchange Web Services. if { [HTTP::header exists "APM_session"] } { persist uie [HTTP::header "APM_session"] 7200 } else { persist source_addr } pool FC-EX2010-DC1-CAS_oa_pool COMPRESS::disable CACHE::disable return } "/oab*" { Offline Address Book. Persistence is not required for OAB pool FC-EX2010-DC1-CAS_oa_pool return } "/rpc/rpcproxy.dll" { if { [HTTP::header exists "APM_session"] } { persist uie [HTTP::header "APM_session"] 7200 } elseif { [string tolower [HTTP::header "Authorization"]] starts_with "basic" } { persist uie [HTTP::header "Authorization"] 7200 } else { persist source_addr } Finally, this assigns the Outlook Anywhere pool. pool FC-EX2010-DC1-CAS_oa_pool If the HTTP profile assigned to your virtual server enables Compression or RAM Cache, you should un-comment either or both of the following lines to turn off the respective feature(s) for Outlook Anywhere connections. If you are using Web Accelerator, un-comment both lines. COMPRESS::disable CACHE::disable return } "/autodiscover*" { Requests for Autodiscovery information. No Persistence. pool FC-EX2010-DC1-CAS_ad_pool return } default { This final section takes all traffic that has not otherwise been accounted for and sends it to the pool for Outlook Web App if { [HTTP::header exists "APM_session"] } { persist uie [HTTP::header "APM_session"] 7200 } else { persist source_addr } pool FC-EX2010-DC1-CAS_owa_pool } } } when HTTP_RESPONSE { if { [string tolower [HTTP::header values "WWW-Authenticate"]] contains "negotiate"} { ONECONNECT::reuse disable ONECONNECT::detach disable NTLM::disable } if {[HTTP::header exists "Transfer-Encoding"]} { HTTP::payload rechunk } } - mikeshimkus_111Historic F5 AccountThere are a few post-config steps that need to be done, like changing any "persist cookie insert" statements in the iRule to "persist cookie insert timeout 0". This is due to a bug where the BIG-IP cookie has an expiration time, even though the cookie persistence profile indicates that it should be a session cookie. If your cookie has timed out, the next request might go to a different CAS and cause problems.
There's a release candidate version of the iApp that takes care of all these post-config steps: https://devcentral.f5.com/wiki/iApp.Microsoft-Exchange-2010-and-2013-iApp-Template.ashx
Is it possible to redeploy using this version of the template? - Josh_41258
Mike,
Can I "upgrade" the existing deployment or do I need to delete the old instance and manually re-configure using the new iApp template?
Thanks,
Josh - mikeshimkus_111Historic F5 AccountWe recommend doing a parallel deployment. The only thing that will conflict is the VIP address. You can create a new instance with the new template using a different IP address for the virtual server, then switch DNS to point to that IP; or you can reconfigure the existing deployment with a different IP, then create a new instance using the production IP address. Then you can delete the old instance.
- Josh_41258
Mike,
Running into a problem. I run two instances of the iApp - one for CAS services, and one just for MAPI/RPC services. The CAS instance works fine until I configure a new instance just for MAPI. Then, the CAS HTTPS related services become unavailable.
Chrome displays: Error 103 (net::ERR_CONNECTION_ABORTED): Unknown error.
Any ideas?
Thanks,
Josh - Josh_41258
It seems to maybe be related to both iApp instances using the same SNAT pool (More than 6000 clients)? But, this worked fine in earlier versions of the iApp.
Josh - mikeshimkus_111Historic F5 AccountActually, the newer version of the iApp uses unique object names for the SNAT pools. Do you have the same addresses in those pools?
When you say that the HTTP services become unavailable, do you mean that the pool members are being marked down? Or are they healthy, but clients just can't connect to them? - Josh_41258
Actually, I'm having problems with the health monitors on various CAS services too. I reverted to the old iApp, and all monitors work fine.
EDIT - It's the EAV monitors that are failing on the new iApp (RC). My AD and OA pools are being marked as down.
- mikeshimkus_111Historic F5 AccountWhich monitor type are you using, simple or advanced? Can you compare the monitor send/receive strings from both the new and old deployments? Are they continuously marked down, or are they flapping?
