iyanus_39384
Dec 01, 2010Outbound iRule STREAM Rewrites for CDN
Hi Folks,
We have a legacy app that has a lot of static content that we want to move to a CDN. I have succesfully created a stream profile to do some of the outbound translation, however this is a lot of management overhead as each asset has to have an explicit source/dest rewrite string pair. Ideally I'd like to do it programatically.
What I am trying to to is rewrite outbound HTTP responses with string replacement of the form
search1: src="/path/to/static/asset.[jpg,gif,png,swf]"
replace1: src="http://my.cdn/path/to/static/asset.[jpg,gif,png,swf]"
I know it sounds easy but I am having major grief getting an iRule to work.
I have tried messing about with STREAM::expression and STREAM::replace but I can't seem to get my regexps to work.
Any Ideas?
Iain
- hoolio
Hi Iain,
You should be able to do this with a STREAM::expression based iRule. In HTTP_RESPONSE, set the STREAM::expression to:
http://devcentral\.f5\.com/path/to/static/asset\.(?:jpg|gif|png|swf)
Then in the STREAM_MATCHED event, you can retrieve the full match using STREAM::match and rewrite the string using string map:when STREAM_MATCHED { log local0. "[IP::client_addr]:[TCP::local_port]: matched: [STREAM::match], replaced with: [string map {http://devcentral.f5.com/ http://my.cdn/} [STREAM::match]]" STREAM::replace "[string map {http://devcentral.f5.com/ http://my.cdn/} [STREAM::match]]" }
For details on the HTTP_RESPONSE code, check the STREAM::expression wiki page:
http://devcentral.f5.com/wiki/default.aspx/iRules/stream__expression
Aaron
