asaf_6512's avatar
asaf_6512
Jul 27, 2008
OneConnect Flush Connection Pool
I would like to flush the existing oneconnect pool of HTTP sessions and have them regenerated.
Does the F5 support flush of the oneconnect HTTP sessions or does it requires restart of the whole F5?
thanks,
Asaf
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    There is no way to only clear OneConnect sessions, but you shouldn't have to restart. Here are a few things to try instead:
    You can clear all connections with the 'bigpipe conn delete' command, or with some filter by IP address.
    You may also be able to modify the settings on the OneConnect profile, setting MaxReuse to 0 & saving it, then resetting to the original value, or simply remove and re-apply the profile to the virtual server.
    hth
    /deb
  • zafer's avatar
    zafer
    Deb,
    if the application guy has security check on server side with client ip address control we can not use oneconnect profile for network based right?
    zafer
