Dietmar_Moltner's avatar
Dietmar_Moltner
Dec 10, 2014
OneConnect & Pool Connection Limits
Hi all,
we are facing a very strange issue with 11.4.1 (latest HF) having OneConnect & Pool Connection Limits & Request Queuing enabled. Under high load (testing), everything is running as expected (Connection Limit on pool as well es right number of connections waiting in Request Queuing pool). Once we take down one of the two pool members and re-enable it, we can see that the member is only taking a lower number of connections (looks like it is Pool Connection Limit - (Pool Connection Limit / of TMM). The limit is never reached again, furthermore it looks like that some stale connections are left in Request Queuing pool leading to Conn Resets.
I am aware about the known bug (Bug 402510), but I assume that it was fixed in 11.4.1.
Anyone else experiencing the same strange behaviour? Can someone confirm if the listed bug was fixed in our release or in 11.5.1 which we plan to upgrade soon?
Thx
  • 11.4.1HF6 does list 402510 as being fixed in that hotfix. If you are running HF6 I would recommend submitting a support ticket on the issue.
