Anthony's avatar
Anthony
12 years ago
NTP not sync'ing - what interface is used?
Hi all,
I'm currently going through a complete reconfigure of our internal loadbalancers and at the moment wI'm stuck on getting NTP working.
Configuring of the internal/external/HA VLANs and assigning all self/float IP's etc is complete, Config sync and failover all work fine.
I've got a list of public NTP servers configured but they all sit at the state of INIT.
This is what I'm getting on all of the servers:
ind assID  status  conf reach auth  condition  last_event cnt
1   12174  8000    yes   yes  none    reject
Runnging ntpq -c "rv 12172" give:
[root@LB1:Active:In Sync] config  ntpq -c "rv 12174"
assID=12174 status=8000 unreach, conf, no events,
srcadr=ntppub.le.ac.uk, srcport=123, dstadr=192.168.74.1, dstport=123,
leap=11, stratum=16, precision=-20, rootdelay=0.000,
rootdispersion=0.000, refid=INIT, reach=000, unreach=37, hmode=3,
pmode=0, hpoll=10, ppoll=10, flash=00 ok, keyid=0, ttl=0, offset=0.000,
delay=0.000, dispersion=15937.500, jitter=0.000,
reftime=00000000.00000000  Thu, Feb  7 2036  6:28:16.000,
org=00000000.00000000  Thu, Feb  7 2036  6:28:16.000,
rec=00000000.00000000  Thu, Feb  7 2036  6:28:16.000,
xmt=d6af521e.ab559847  Wed, Feb 19 2014 15:54:06.669,
filtdelay=     0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00,
filtoffset=    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00,
filtdisp=   16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0
The firewall all seems to be clear of any blocks on the IP adresses that have been configured, so what else could be the likely cause of something like this?
Thanks in advance for any advice.
Anthony
