not definable syslog mesaage
Hallo all,
ich bekomme dauernd folgende meldung: httpd[15271]: [error] [client 127.0.0.1] (104)Connection reset by peer: proxy: error reading status line from remote server localhost
httpd[15271]: [error] [client 127.0.0.1] proxy: Error reading from remote server returned by /mgmt/tm/sys/software/status
Does anyone have an idea what this may be?
- amolari
those are internal communication messages (that returns the software versions installed on your BIGIP volumes). I suggest you to open a support case by F5.
- Andre-Germany
And does that mean?
I hve see its only on all vcmp guest and not on the vcmp host.
- SL
Cirrus
Anyone have any feedback on this?
- aSuperUser
Do you receive feedback and have a solution?
- Vik_K_236702Historic F5 Account
Hi Udo
Looks like the VCMP guests are not able to get the platform type.
Can you also tell what version your devices are on ?
In any case, please open a case with F5 support and they should be able to help you out with this.
Regards, Vikram Khatri
