mohit29388_1794's avatar
mohit29388_1794
Jul 12, 2016
Not able to connect 2 way SSL from application server to f5
From my application server , for client side connections towards my f5 i am trying to establish a 2 way ssl , but am not able to connect
[client server ~] openssl s_client -connect f5.c1.com.gn:9010 CONNECTED(00000003) depth=0 C = GN, O = MTN, CN = f5.Cust1.com.gn
verify error:num=20:unable to get local issuer certificate
verify return:1 depth=0 C = GN, O = CUST1, CN = f5.Cust1.com.gn verify error:num=27:certificate not trusted
verify return:1 depth=0 C = GN, O = CUST1, CN = f5.Cust1.com.gn verify error:num=21:unable to verify the first certificate
verify return:1
Certificate chain 0 s:/C=GN/O=CUST1/CN=f5.Cust1.com.gn
i:/CN=m3-internal-ca-guina
Server certificate -----BEGIN CERTIFICATE-----
-----END CERTIFICATE----- subject=/C=GN/O=CUST1/CN=f5.Cust1.com.gn
issuer=/CN=m3-internal-ca-guina No client certificate CA names sent SSL handshake has read 1263 bytes and written 621 bytes
New, TLSv1/SSLv3, Cipher is AES256-SHA256 Server public key is 2048 bit Secure Renegotiation IS supported Compression: NONE Expansion: NONE SSL-Session: Protocol : TLSv1.2 Cipher : AES256-SHA256 Session-ID: E712FFC846A4669E74AC3793C2A0E3E41714CE2DB06FEF08CD90D81A210F0593 Session-ID-ctx: Master-Key: 12F2D283B35FD56F25EA30CED9239BAA5155C692024DCA9C1E3400539D123637 8921C39456C9DBD399B3D99444497465 Key-Arg : None Krb5 Principal: None PSK identity: None PSK identity hint: None Start Time: 1468237189 Timeout : 300 (sec)
Verify return code: 21 (unable to verify the first certificate)
read:errno=0
along with this iam getting following error on server :
https://f5.cust1.com.gn:9010/********: peer not authenticated
  • my F5
    Sys::Version Main Package Product BIG-IP Version 11.5.4 Build 0.56.256 Edition Engineering Hotfix Date Fri Mar 25 14:46:24 PDT 2016
    one doubt which I have :
    on F5 chippers is selected as default
    while at my application server end
  • Part of the error message is that you're not defining a CA cert (or trust bundle) in your OpenSSL command so the client side is unable to validate/trust the server certificate. But when you say 2-way SSL, are you talking about using a client certificate as well?
  • Hello,
    I am trying to establish 2 way ssl on my client server with f5 I created a cert for F5 > associated it with profile and VS
    and similar way I created client cert. for server as well in configured it to present for ssl handshake
    but im getting errors:
    peer not authenticated ssl handshake failure
    above is O/P from my client server which I try ssl connection towards F5
  • I am trying to establish 2 way ssl on my client server with f5
    Please confirm that you mean that you're trying to do SSL mutual authentication with server AND client certificates.
    As I mentioned before, part of the error is that you're not providing a way in your openssl command to validate the server's certificate. You need to define a CA certificate, or certificate bundle. If you are doing mutual SSL authentication, then you're also not providing the client cert as part of that openssl command.
  • Please confirm that you mean that you're trying to do SSL mutual authentication with server AND client certificates.
    yes you are correct .
    can you help me with correct command syntax
