RiverFish's avatar
RiverFish
Oct 04, 2012
Newby needs irule help
Greetings. The software guys assigned this task to me, can anyone please help me come up with an irule?
"Please write an IRule or some kind of filter that inspects the last_login Cookie in the Http Resonse Header sent from our weblogic application servers.
The Cookie will have a Name of last_login, the Content field will contain the username and this is the element we want to filter on.
During times of troubleshooting program staff will contact someone in IT and ask them to enable this filter for some username. The expectation is this filter can sniff the response header where last_login=SomeUserName and write some dianostics to a file, such as the time and HTTP Header."
  • e.g.
    [root@ve10:Active] config  b virtual bar list
    virtual bar {
       snat automap
       pool foo
       destination 172.28.19.79:80
       ip protocol 6
       rules myrule
       profiles {
          http {}
          tcp {}
    [root@ve10:Active] config  b rule myrule list
    rule myrule {
       when HTTP_RESPONSE {
       if {[HTTP::cookie exists last_login]} {
          foreach aheader [HTTP::header names] {
             log local0. "[IP::client_addr]:[TCP::client_port] | ${aheader}: [HTTP::header value $aheader]"
     on client
    [root@centos251 ~] curl -I http://172.28.19.79
    HTTP/1.1 200 OK
    Date: Thu, 04 Oct 2012 17:16:06 GMT
    Server: Apache/2.2.3 (CentOS)
    Last-Modified: Fri, 11 Nov 2011 14:48:14 GMT
    ETag: "4183e4-3e-9c564780"
    Accept-Ranges: bytes
    Content-Length: 62
    Set-Cookie: last_login=tasmania path=/
    Connection: close
    Content-Type: text/html; charset=UTF-8
     on bigip
    [root@ve10:Active] config  tail -f /var/log/ltm
    Oct  5 00:59:48 local/tmm info tmm[4907]: Rule myrule : 172.28.19.251:49826 | Date: Thu, 04 Oct 2012 17:16:06 GMT
    Oct  5 00:59:48 local/tmm info tmm[4907]: Rule myrule : 172.28.19.251:49826 | Server: Apache/2.2.3 (CentOS)
    Oct  5 00:59:48 local/tmm info tmm[4907]: Rule myrule : 172.28.19.251:49826 | Last-Modified: Fri, 11 Nov 2011 14:48:14 GMT
    Oct  5 00:59:48 local/tmm info tmm[4907]: Rule myrule : 172.28.19.251:49826 | ETag: "4183e4-3e-9c564780"
    Oct  5 00:59:48 local/tmm info tmm[4907]: Rule myrule : 172.28.19.251:49826 | Accept-Ranges: bytes
    Oct  5 00:59:48 local/tmm info tmm[4907]: Rule myrule : 172.28.19.251:49826 | Content-Length: 62
    Oct  5 00:59:48 local/tmm info tmm[4907]: Rule myrule : 172.28.19.251:49826 | Set-Cookie: last_login=tasmania path=/
    Oct  5 00:59:48 local/tmm info tmm[4907]: Rule myrule : 172.28.19.251:49826 | Connection: close
    Oct  5 00:59:48 local/tmm info tmm[4907]: Rule myrule : 172.28.19.251:49826 | Content-Type: text/html; charset=UTF-8
  • Thank you very much! I think I understand everything here. I'll put it in place and see how it goes.
  • They have modified their request. Any help would be much appreciated. New request below:
    I'd like to make a modification to this request if we can. After further investigation we think it would be better to grep/filter the Response HTTP Header for a custom header we set instead of the last_login Cookie.
    We place the following header in the HTTP response when we have ARMON enabled on our side.
    The token to filter on is NTTN_ARMON
    Here's a example header
    Response Headers
    HTTP/1.1 200 OK
    Date: Fri, 05 Oct 2012 18:19:33 GMT
    Transfer-Encoding: chunked
    Content-Type: text/html; charset=ISO-8859-1
    Host-Address: 10.204.4.239
    NTTN_ARMON: jsmith,420,1348
    Host-Name: jsmith
    X-Powered-By: Servlet/2.5 JSP/2.1
    If we can sniff the response headers for:
    // all users
    NTTN_ARMON
    // and for a specific user
    NTTN_ARMON: ${some-username}
    then write/log an output of
    [time-f5-saw-response], [content of NTTN_ARMON header]
  • The rule is pretty close to the last one:
    if { [HTTP::header exists NTTN_ARMON] } {
    log local0. "[clock format [clock seconds] -format {%Y-%m-%d %H:%M:%S}], [HTTP::header NTTN_ARMON]"
  • Is there an easy way to direct the output of this iRule to it's own dedicated log instead of the system log?
  • Maybe you'll find your answer here:
    https://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/44/aft/1172420/showtab/groupforums/Default.aspx
