gossett_151899
Apr 25, 2014NEWBIE!! I need help setting up a PPTP VPN using BIGIP-LTM
This is my first day at a new job and very first time using the BIGIP-LTM. In talking with the comrade before me there are two things that we have set up: the LSN pool and ALG PPTP. I also found that I need a selfIP (though I can't find out in the doc what this means). Any help or direction on this would be amazing. Thanks you.
- TechNTactical_1Historic F5 Account
What version of Big-IP are you running?
Go to System > Configuration > Device > General to find out. That will help me give you better instructions because it sounds like you are starting from scratch.
- gossett_151899
BIG-IP 11.5.0 Build 0.0.221 Final I appreciate your help more than I can possibly say. Yes i'm starting from scratch and I have no experience with firewall or NAT type devices. You can bet i'm learning really quick :)
