Dean_01_141460's avatar
Dean_01_141460
Apr 17, 2014
Network Solutions ssl csr with F5 11.5.1
We have purchased our certs from Network Solutions in the past and we recently upgraded to 11.5.1. When I go to post the csr into Network Solutions form I get a error stating "The CSR provided uses an unsupported signature algoritm. Supported algorithms are: md5withrsa, sha1withrsa, oid 1.2.840.113549.1.1.4. oid 1.2.840.113549.1.1.5". I called Network Solutions support and there was no way around it. I then went to a older F5 we have running 9.4.4, created the cert, exported the csr and Network Solutions took it. Anyone experience anything similar or know if F5 changed the ssl signature algorithm in the latest release?
  • i think 11.5.1 uses sha2 as signature algorithm. you may use openssl command instead.
    [root@ve11a:Active:In Sync] config  tmsh show sys version
    Sys::Version
    Main Package
      Product  BIG-IP
      Version  11.5.1
      Build    0.0.110
      Edition  Final
      Date     Wed Mar 12 15:44:53 PDT 2014
    [root@ve11a:Active:In Sync] config  openssl req -text -noout -in /config/ssl/ssl.csr/testcsr.csr |grep Signature\ Algorithm
        Signature Algorithm: sha256WithRSAEncryption
  • Honestly you should be wanting to move your signing algorithms to SHA2 anyway. Microsoft has already announced that deprecation date for SHA1 as 1/1/2016 and that by 1/1/2017 Windows will not accept any SHA1 signed certificates.
    http://blogs.technet.com/b/pki/archive/2013/11/12/sha1-deprecation-policy.aspx
    Also you can reference this NIST guidance for moving forward as well. If you want to take the time to read through it :)
    http://csrc.nist.gov/publications/nistpubs/800-57/sp800-57_part1_rev3_general.pdf
    Personally I would questions your CA as to why they will not allow you to use a more secure algorithm. I can understand allowing for you as the customer to choose to issue at SHA1 for compatibility issues, but not even allowing SHA2 as a choice seems like a bad decision to me. I am currently issuing everything as SHA2 unless there is a technical limitation on a server that requires SHA1.
  • We are experiencing the same frustration with Network Solutions now. I do not have an older F5 to generate the CSR from unfortunately. Any suggestions on a workaround?
  • The only workaround I can think of is what nitass said, use the command line openssl. You can do this on probably any linux box, on the F5, or even cygwin on windows(with openssl installed)
    Gen a CSR with a new Private KEY: openssl req -out CSR.csr -new -newkey rsa:2048 -sha1 -nodes -keyout privateKey.key
    You will need to import the above privateKey.key into the F5 along with your new certificate. Remove the -nodes if you want to password protect the private key.
    If you want to reuse a private key, use: openssl req -out CSR.csr -key privateKey.key -new -sha1
    • mimlo_61970's avatar
      mimlo_61970
      Also, see http://www.sslshopper.com/article-most-common-openssl-commands.html for more openssl command line help
