Nested switch in HTTP_REQUEST/ignore case
I'm trying to create an iRule that only allows specific domain/URI but also allows specific wildcard directories (i.e. "/Images*") and ignores case. Example below works great for limiting the host/URI and ignoring case but switch does not work. I hope I can explain this clearly...
so my end goal would basically be...
https://XYZ.com/advocateprofileservice.svc = pool
https://XYZ.com/AdvocateProfileService.svc = pool
https://XYZ.com/internal/advocateprofileservice.svc = 403
https://XYZ.com/internal/AdvocateProfileService.svc = 403
https://XYZ.com/Images/test.jpg = PASS (currently not working)
https://XYZ.com/internal/Images/test.jpg = 403 (currently not working)
all else = 403
=====EXAMPLE=====
set uri [string tolower [HTTP::uri]]
switch [HTTP::host] {
"XYZ.com" {
switch -glob [HTTP::uri] {
"/Images*" {
pool XYZ_pool}
if { [HTTP::host] equals "XYZ.com" and $uri equals "/advocateprofileservice.svc" or
[HTTP::host] equals "XYZ.com" and $uri equals "/advocateprofileservice.svc?singlewsdl" or
[HTTP::host] equals "XYZ.com" and $uri equals "/advocateservice.svc"} {
pool XYZ_pool
} elseif {[HTTP::host] equals "XYZ.com"} {
HTTP::respond 403
- StephanManthey
Nacreous
the iRule below should solve it:when HTTP_REQUEST { set uri [string tolower [HTTP::uri]] if {[string tolower [HTTP::host]] equals "xyz.com"} { switch -glob [string tolower [HTTP::path]] { "/images*" - "/advocateprofileservice.svc" { pool xyz_pool return } default { HTTP::respond 403 return } } } else { HTTP::respond 403 return } }Please see the wiki pages for switch regarding the syntax details.
For testing you may want use cURL directly on your BIG-IP as follows:curl -v -X HEAD -H "Host: xyz.com" "http:///images/test.jpg" curl -v -X HEAD -H "Host: xyz.com" "http:///internal/test.jpg" curl -v -X HEAD "Host: xyz.com" "http:///advocateprofileservice.svc" curl -v -X HEAD "Host: xyz.com" "http:///internal/advocateprofileservice.svc"Be aware, that all changes to your iRule will affect new connections only. For testing with a browser you may want to close all open browser windows after applying a change to your iRule.
Thanks, Stephan
