Mubasher_Sultan's avatar
Mubasher_Sultan
Dec 19, 2013
Need to Understand the Hardware (Serial) Failover Vs Network Failover in F5 - LTM v11.3?
Hi Folks,
I had a version 10.2 with Hardware Failover and now we upgraded the system to 11.3 HF8.
We had a hardware failover enabled only. When we planned to upgrade into 11.3, we got the recommendation to use the Network Failover.
I need to understand that what is the advantage of using the network failover over hardware failover. Need to understand that what to use and whats are the benefits...
If we are using both together, then both should happen to do a fail-over to be happen...
I also read the below http://support.f5.com/kb/en-us/solutions/public/2000/300/sol2397
F5 recommends Hardware failover then why and where do we need Network failover except we have a long distance between devices or viprion or Active / Active configuration.
Please advise or correct me if i am wrong!
Thanks,
Regards, Mubasher
