Kumar_107292's avatar
Kumar_107292
Feb 03, 2013
Need to Modify Monitor and Virtual Server protocols
Hi
I have two questions here: First - How can I modify templateType for a Monitor?
Second - I need to modify protocol of Monitor and Virtual Server.
When I am doing it like setProtocol for Virtual Server It is failing and giving error message like :
Exception caught in LocalLB::urn:iControl:LocalLB/VirtualServer::add_profile()
Exception: Common::OperationFailed
primary_error_code : 17236117 (0x01070095)
secondary_error_code : 0
error_string : 01070095:3: Virtual server /Common/VS_KumarPolicy_155497_155 lists incompatible profiles.
Like Wise when I am sending a request to change Monitor protocol by sending :
iCtrlMonitor.set_template_string_property(monitorTemplates, lbMonitorStringValues); I get error like:
Exception caught in LocalLB::urn:iControl:LocalLB/Monitor::set_template_string_property()
primary_error_code : 16908342 (0x01020036)
error_string : 01020036:3: The requested monitor parameter (/Common/MyMonitorName 1 PROTOCOL=) was not found.
How can I modify my protocols without recreating Monitor and VirtualServer.
Kumar
