Amit787's avatar
Amit787
Oct 06, 2020
Need to forward traffic on specific pool according to uri over 500 urls
Hello
I am having requirement to setup new url "example.com" and when user try to access
"example.com/user1" traffic should be on "pool1"
"example.com/user2" traffic should be on "pool2"
"example.com/user3" traffic should be on "pool3"
"example.com/user500" traffic should be on "pool500"
Need dynamic way to achieve this, instead of writing 500 lines of code.
Please advice.
Thanks,
Amit
  • Hi Amit,
    Can you try this iRule?
    	if { [HTTP::host] equals "example.com" && [HTTP::uri] matches_regex {\/user[0-9]{1,3}} } {
    		set poolID [string trimleft [HTTP::uri] "/user"]
    		set poolname "pool$poolID"
    		# log local0. "poolname: $poolname"
    		pool $poolname
  • Thanks you sooo much "eaa". Solution worked.... :)
  • And thanks a lot for your quick support as well... ​
