Abhishek_02_152
May 02, 2014Need to check for a specific output of a webpage
Hi all,
I am looking for a help to create a health monitor. We would like to use one specific URL which will allow automatic login. If this page fail to load then we will consider that servers are down. Application is BMC remedy
- Kevin_Stewart
Employee
The thing is, none of the cURL tests you've provided have this string in the response. If you can provide a request that reliably returns a cacheid value in the response, then you could certainly use in the monitor.
